Kingofpain678
Returned from the dead
I didn't really know what forum to post this in and since the newbies forum is sort of a general knowledge area I figured it would be OK to post it in here. Mods if you wanna move it that's fine.
Ok, so I got my PC in a separate room to cut down on noise (thank god
) and I've got all my cables run to where they need to go except for my monitor cables. My AI output is balanced but unfortunately the 1/4" inputs on my monitors are unbalanced. So In order to keep the benefits of a balanced signal I need something that would take the balanced signal and convert it to unbalanced right before it hits the monitors so that way I can make my unbalanced cable run as short as possible.
So what I'm obviously gonna need is a transformer but I'm not sure if there is another component that I would need to keep the benefits of the balanced signal. Would a in-line transformer do the job or would I need something else?
) and I've got all my cables run to where they need to go except for my monitor cables. My AI output is balanced but unfortunately the 1/4" inputs on my monitors are unbalanced. So In order to keep the benefits of a balanced signal I need something that would take the balanced signal and convert it to unbalanced right before it hits the monitors so that way I can make my unbalanced cable run as short as possible.So what I'm obviously gonna need is a transformer but I'm not sure if there is another component that I would need to keep the benefits of the balanced signal. Would a in-line transformer do the job or would I need something else?
