F
fearfeasog
Member
Hi all, i have a small (~15 x 13') room that i plan on making a studio. well it'll be multi-use, as you will see. but my main concern is getting the sound controlled in there. the room is an 'L' shape, as a shallow closet impinges on the space a bit. I'm attaching a few photos and a floor plan (with proposed panel locations) as a reference.
My plan is to construct my own panels using OC 703. i can afford 12 sheets of 2", so i thought i'd make 4 panels @ 4" and 4 panels @ 2". I'm also thinking it might be necessary to think more flexibly and consider making 2' x 2' panels if needed, or possibly narrower panels to fit into tighter spaces.
i really need some advice on placement--both of the workstation and the panels. the workstation could go at either end of the room. (in the photos it's on the west end, but in the plan it's on the east end) panels at reflection points are a given, left, right and above, as well as behind the monitors, and the inside corner of the "L" might need some treatment too, especially if the monitors face into it. but after that, given what i have to work with, i wonder what you all would advise?
this is one possible location for the workstation: it would go wnere the bookcase and the stuffed person are...
left side of that wall:
right side:
this is looking back from there into the inside of the "L":
and this is the other end of the room:
Here's the overall plan, with a proposed setup for the panels, in red:
if you need more info, please let me know. i really appreciate your help!
mark
right side:
mark
