2488 neo... can I do 24 mono tracks????
  • Thread starter Thread starter waxdat
W
waxdat
Can I record 24 mono tracks using the virtual tracks and mix them all down, then master them. I know there are only 12 physical faders for mono and 6 stereo. Is this at all possible?
You can bounce premixed individual tracks from 1 to 12 to stereo tracks 13 to 24 and get 24 separate tracks.
Yes. Though, I'm not sure what Philboyd means by "pre-mixed", you can simply clone any track from 1-12 to any track from 13-24. I often record a track on Track 5 (for example) and then clone it to Track 13 (for example), and then record another track on Track 5 and clone that over to Track 14, etc.......
Yes, cloning is the easiest and fastest way. I'll bouce (record) to 13 - 24 if I need space and want to keep eq and effects since I record dry.
cloned track volume too low
i've tried cloning tracks on my new 2488, from track 1 to 2 or 3 for example.
the result was that the cloned tracks were incredibly low volume.
never had that experience with the 788.
volume levels were all up. not that it mattered i suppose as i was cloning a track.
cloning tracks is a pretty simple thing. if this continues should i assume there is
a defect in the unit?
