How much of that solo did you "write" ?
  • Thread starter Thread starter YorkshireTrippe
  • All of it! I can send you the sheet music if you like
    Votes: 10 45.5%
  • The basic melody, but I improvised a few embelishes and runs
    Votes: 3 13.6%
  • I kind of knew what key I was in but its basically improvisation
    Votes: 5 22.7%
  • write? I just turn the gain up and hit the fretboard with my fists
    Votes: 4 18.2%
  • Total voters
    22
YorkshireTrippe
YorkshireTrippe
Since I promised myself to double track as much of my playing as possible, I've found myself literally sitting down and tabbing out bits of my own playing so I can get it spot on - is this really what most guitarists do? or am I being overly fussy and should I just single-track the solos?
I'm interested in what you guys do :cool:
i farm most of the solos out, but never double them. i ain't the alman bros ffxs
I've found myself literally sitting down and tabbing out bits of my own playing so I can get it spot on...
Can't you just play it back and listen/learn it that way?
I mean...it's YOUR playing, so it shouldn't take a lot of effort for you to copy yourself with just a few dry runs.
I've never written down my own riffs in order to learn them.
I mean...why would I...I already know them...I just played them! :)
I think solos (even when they're "written") are usually single tracked. Double tracking the rhythm parts makes a nice stereo spread for the solo to sit in the middle of.
I usually start of improving solos--but after a gillion takes trying to get it "just right" it ends up writing itself, so that I can do the same thing over and over and again. Even then I single track it--often using a touch of stereo delay to thicken it.
ez mentioned the Allman Bros--a great example for when I might do it. Their solos were doubled for effect--to sound like two guitars playing two parts, not one thicker guitar. I'll do some lines of split left/right harmony in a lead occasionally.
I try and play the whole song in one take without punch-ins, so I'd forget how many triplet sets were in that run and stuff if I didn't write it down
I improvise everything.
I almost always have a rough, eh, "contour" of a solo in mind, sort of like a picture of where I want it to end up ("open with some high bluesy bends, over this section some fast ascending legato over the neck, do a slide-y wide interval bit through here, and then finish with a descending legato flourish in this area ending with a harmonic dive") or some such thing, so I'll have an idea of roughly what I want to do, but I never sit down and work out each individual note. Doing that bores me and takes the fun out of it, and I write and record music because I think it IS fun.
how long would it typically take to tab out a solo that you just tracked?
I "write" almost all my recorded solos, although it might be more accurate to say that I "craft" them since I don't actually score them. Only one of the tunes that I have posted on Soundclick has an improvised solo; the remainder are intentional and repeatable.
I don't score them out. I go through an iterative process of record, listen, re-record, listen, repeat as necessary. When I've got the proper elements in place I rehearse it over and over until I can get through a tracking of it error-free. At that time I may experiment with different guitars or amp settings.
i meant to physically score the tab out. i ain't good enough to improvise anything.
I hear ya. ;)
I figure that if I've developed the muscle memory for a solo enough to play it all the way through, the recording of it serves as enough of a permanent ...record... for me to be able to reconstitute it.
I've got a couple of tunes running around in my head that will likely use 100% improvisation for solos and fills, though. I have a couple of guitar playing comfort zones in tempo and construction where I can just let 'er rip and everything sounds good. :)
Mmmmm....I guess if it's a real long solo....but still, I would think most of the solo is probably already in your memory...so you only need to practice/learn certain sections.
Play/record it one time...and then play along with that a bunch of times until you have it down, then record the second pass.
But you know...punch-ins are allowed during recording, ;) and if you don't want to punch-in, then just play/record it straight through a few times...and comp the takes as needed.
I write about 90% of my music without any instrument in my hands at all. I use guitar pro, come up with the stuff in my head and tab it. I never improvise.
The closest I'd get to improvising is changing my mind about a part while I'm recording it, and take about ten minutes coming up with a new part and getting it down in my head.
Just the brown ones........
You lie! They're ALL brown ones, at least when you're done with them! :eek:
My problem, mirosav, is that not only do I improvise everything, I also generally solo right at the limits of my technical aptitude. So, even if I sat down and worked out what I had just played (which would be a huge pain in the ass, because that's a LOT of note! :p), it would take me forever and there's no guarantee I even could replicate it with 100% accuracy. Sometimes you go for a line and it works; sometimes not. At the very least, a solo that I'd have just improvised comfortably would probably require a fair amount of practice to then go back and duplicate it perfectly.
Of course, I don't really have any interest in doubling or harmonizing the lead breaks in my material, so it's not an issue. :D
I'll double-track a lead if it is the sound I'm looking for. It's a distinctive sound, and I'll use it if I want to develop a theme within a solo and want to get "bigger" but not "louder".
It's a useful tool, but for really long solos it would be tough.
Well, I suck anyway so it's all tough - but you know what I mean.
