C
cadbawdbawks
PROBLEM SOLVED - Solution underneath!
I have an M-Audio DMP3 mic preamp that just doesn't want to stop making a low humming noise. I've tried everything to my ability including spreading out the cables and moving them around to make sure that they are not twisted together, plugging the power supply into the wall and different sockets, using a 3 prong to 2 prong converter for the power supply, using different xlr and trs cables, using different mics. Everything leads right back to a low hum that gets unacceptably loud with any significant raise in gain. The low humming begins as soon as I turn on phantom power. I've tried using the built in preamps that came with my interface with the exact same cables and mics and there was no humming noise to be found. This is driving me crazy...
One thing i should point out is that my ac adaptor is an OEM UK one which I have plugged into a universal adapter to change it to a 3 prong North American plug. Don't know if that could cause any problems, I haven't been able to find the original M-Audio DMP3 ac adaptor anywhere for sale. The M-Audio online store is all out of stock on it.
So here's how I have everything hooked up just for your info:
Condenser Mic --> 25' XLR Cable --> DMP3 In --> DMP3 Out --> 20' TRS Cable --> Tascam US 122 Interface Line In
The power supply and adapter:
Thanks! Your help is much much appreciated!
-------------------------UPDATE!!-----------------------------------UPDATE!!-----------------------------------UPDATE!!-------------------------------
SOLUTION FOUND!
I missed the obvious fact that North American sockets are 110V and British sockets are 230V and since my wallwart is not a dual voltage adapter, a step up transformer would then be of much importance. So I went around looking for a place that sells voltage converters (aka step up transformer) and I happened to stumble across a local foreign electronics store that sold 100W step up/down transformers for only $20 CAD. I brought it home, plugged it in, and what do you know, not only does the preamp turn COMPLETELY SILENT but the lights in the vu meters are glowing bright yellow in broad daylight!
The uk wallwart was not getting enough input to output the full 9v (credit to Johnsuitcase for figuring that out) and hence the preamp began buzzing on phantom power (buzzing = straining the preamp to squeeze out excess power on 48v) and the lights were barely going on.
I hope this is going to be of some help for those who are experiencing the same/similar issues.
Thanks again for everyone's help! I really do appreciate it!
SOLUTION FOUND!
