Thanks so far...
anyone tried the Tube MP Studio V3?
Most of what's been suggested so far has been way out of my price range.
I figured as much from your first post. I'm in the same boat...most of this recording gear the guys on here suggest is beyond the means of your regular Joe. (even if it was, it would be hard to get passed the wife!)
So my advise will prove to be most useful to you, being that I have a "real world" view of things. (real world = real poor)
I was dissatisfied with my results, using the usual stage mics (SM57/58, E-V, AKG, etc) and an
M-Audio Black Box as my digital interface. (I also have an M-Audio 24/96 Audiophile soundcard)
My instruments sounded fine (the Black Box does a great job for the $$$), but any time I tried to mic something (esp. vocals) it would fall short. Even adding the VST plugin "Vocal Magic 5" didn't bring the desired result.
Aside from "deadening" the room you record in, a good dedicated studio mic (as much $$ as you can afford) and a simple preamp w/compression will work wonders. (get one with a digital output if you can afford it)
I'm gonna assume you have a decent interface, whatever it is.
I bought a Blue Bluebird mic on Ebay. My winning bid was $200. (Retail $299)
It sounds great with much detail and high end. (albeit the shockmount is mediocre) Worth every penny! But I wouldn't say it's perfect for every application.
For vocals, You'd be hard pressed to find better for the money.
The preamp thing is trickier.
Those ART units sound great in text:
"...made pro-caliber tube preamping available to ordinary musicians and home studios"
(no doubt making ordinary recordings)
"Provides Superior Preamplification for: Microphones, Instruments and Line Level Sources"
(superior to what? Avalon? Neve? AU?)
"Hand-Selected 12AX7A Vacuum Tube"
(Probably still has the oil on it from the dirty fingers that selected it)
...{out of a box containing ten thousand 12AX7s, bought in a lot from Shady Bonsai Distributing Inc.}
"Built-in Brickwall Limiting"
(well, if that doesn't tell ya something about it's limitations....)
The cheaper units will give you some of the basic necessities you need for recording with a mic, but the quality is usually below average. Poor quality control make individual units vary greatly in performance and some units can be quite noisy.
But it's all relative. This goes for several of the cheaper units. Mass production leaves lots of room for error and cheaper companies cut corners when they can.
I know someone that bought this unit:
http://pro-audio.musiciansfriend.co...nel-Variable-Impedance-Tube-Preamp?sku=180632
They figured it would be better than the $29 unit, but it added just as much noise as the $29 unit. (maybe more!)
After much research, I purchased the Focusrite Trakmaster Pro. ($125 on Ebay..retail $339) and bought the optional ADC card ($225) to give it a digital output.
That gave me a relatively quiet preamp with a decent (albeit limited) compressor that has a digital out. ($375 total cost)
Is it as good as an Avalon? I'll probably never know....but I doubt it is...and it probably won't ever be an issue with me. But then, I'm not a pro studio, I'm just a guy...like you.
I also have to add, a pop filter is another must for recording good vocal tracks. If you're tight for cash, get an old pair of pantyhose, stretch them through your mom's embroidery hoop and tape it to the mic. (just make sure not to use the crotch area)
...unless you like that sort of thing
I bought this instead:
http://pro-audio.musiciansfriend.com/product/Raxxess-Pop-Filter-Kit?sku=421640
Smells much nicer.
