kcearl
I see deaf people
Just thought Id share some of this...most of its available on the web, or articles, I just put it together...
15 Reverb tips
Diversify
Rather than trying to make everything in the mix in the same acoustic environment,
why not use a couple of really diverse reverbs to add some strange depth to your
tunes? A really dry, upfront vocal works nicely alongside a really 'drowned' string
section or a small bright room setting on the drums.
Automate
Try automating return levels if you have a digital mixer so that the reverb comes
and goes in different sections of the song. By tweaking the aux send levels,
manually, during the mix you can add splashes of reverb on the fly to add interest to
snares or vocal parts.
Take your time
Spend some time choosing or trying out different 'verbs. Different songs lend
themselves towards different types and sounds. Don't just settle with what sounds
good in solo...
Send that EQ
Remember you can always EQ the send. Most large consoles offer you a choice of
high and low EQ on the aux sends. On small desks, route the instrument/voice to
another channel via a group or aux send, float this from the mix and send this to the
reverb effect. Now you can add EQ to the send and even automate it as it's now on
a fader. This is commonly used for those delays and reverbs that you want to move
easily during the mix, such as wetter vocal in the chorus.
Old tricks
Reverse reverb is an old trick, where you can hear a vocal before a singer comes in, or a snare before it plays,
easily using tape as you simply turn the tape over and record it backwards. You can do it using a computer, but
you will have to move the audio to the right place after recording it.
Use combinations
A combination of reverbs on things can be good. A short setting for the snap sound with a longer bright plate can
turn a biscuit-sounding snare into a more live sound.
Old school plate
In the old days it used to be called delay to plate. You sent the signal to a loop of tape then sent that to the reverb.
The speed of the tape would adjust the delay as the time it took to get from the record head to the playback head.
This gives, say, a voice a dry sound before the reverb comes in, giving a more upfront sound while keeping the
wetness, which would usually take it to the back of a hall somewhere! Some people still use the tape method
today for that old school sound.
Simple drum one
Early reflections on drums can also give more of a tail or decay.
Experiment
A nice gated verb on guitars to old spring verbs on snares or even the mighty space echo can sound unique when
balanced in the mix. That will give you more distance and room for placing things in a mix, while adding that extra
sparkle to the sound.
More reverse
Reverse your sample, add reverb, then reverse your sample complete with reverb back around the right way
again. This way, the reverb trail leads up into the sample, instead of trailing away from it.
And again!
For a different angle on the same reversed reverb theme, have the reverb trail panned left on a separate track,
then the original sample centre-stage (ie. mono), followed by a regular reverb trail on another track panned right.
The result is a reverb that leads up into the sample and trails away afterwards, while panning across the stage,
left to right.
Reverb over your mix
Pick out key instruments or sounds and highlight them with reverb while using reverb sparingly, if not at all, on the
remaining mix. You may have to adjust reverb send levels as the track progresses so you're not left with the track
sounding dry where the reverbed sounds are no longer playing.
Reverb and bass
Usually, bass and reverb don't mix too well, unless you're specifically arft ea warehouse sound. Unfortunately, this
effect results in a loss of definition among the bass regions. Run your reverb returns into a couple of spare
channels in your mixer and back off the bass EQ, or add a high-pass plug-in EQ.
Go mono!
Don't forget suing mono reverbs at times as well. These won't conflict with your rich stereo reverbs.
Pre delay
This determines time taken for
the initial reflections to return back from room walls. Use a calculator from www.hitsquad.com/smm to get a pre
delay value matched to your tempo.
A common technique is to set the predelay to eighth-notes and add the reverb to a straight quarter note kick drum
pattern to create an off-beat bouncy feel.
			15 Reverb tips
Diversify
Automate
Take your time
good in solo...
Send that EQ
Old tricks
Use combinations
Old school plate
Simple drum one
Experiment
More reverse
And again!
left to right.
Reverb and bass
Go mono!
Pre delay
