N
NYMorningstar
Recording Modus Operandi
Here's an easy way to find your Key signatures.
W=whole step
H=half step
S=start
Here's the basic pattern of the major scale W W H W W W H.
You can utilize that to determine different Key signatures by substituting the starting point notes.
For example let's start with the key of C which has no sharps or flats. We start with the c note(always start with the key note) and work upscale. The dashes are for spacing only:
S - W -W- H - W-W- W - H
c - d -- e - f --g - a - b - c
This shows from c to d there is a whole step. From d - e there is a whole step. From e - f there is a half step. From f to g there is a whole step and so on... This scale is based on the Key of C, no sharps, no flats. Every note is played natural.
Now let's try it for the Key of G:
S - W - W -H -W -W-W- H
g - a -- b - c --d - e - f - g
This shows from g - a there is a whole step. From a - b there is a whole step. From b - c there is a half step. From c - d there is a whole step. From d - e there is a whole step. This is where it gets interesting. It shows from e to f there is a whole step. Woa, if you go a whole step from e then you are at f #. Well ok, this means that all the f's in the Key of G have to be played sharp. It also means that the Key of G has one sharp. Thus, when you see a Key signature with one sharp you know it is the Key of G. To make things even easier you will also see that sharp symbol actually located on the line F in the music staff.
Let's try it with one a little tuffer, the Key of E.
S -W- W- H - W -W-W -H
e - f --g - a --b - c -d - e
This shows from e - f there is a whole step.(f's are sharp). From f# to g a whole step. NOTE: Since f's are played sharp, then a whole step would go to g sharp.(g's are sharp). From g# - a is a half step. Note: since g's are sharp then a half step goes to 'a' natural(a's are natural). From a - b there is a whole step(b's are natural). From b - c there is a whole step(c's are sharp). from c# - d there is a whole step(d's are sharp). Last but not least from d# to e there is a half step(e's are natural).
If we add them up the we see the Key of E has 4 sharps! OMG. That's a hard key for alot of peeps to wrap their head around when reading music.
This works for all Keys, including flat Keys.
W=whole step
H=half step
S=start
