Recording with adobe audition 3
  • Thread starter Thread starter y-kause
y-kause
y-kause
k. i went from acid pro 7 to adobe audition 3 because i heard thats a better program 4 what i need as far as mixing n mastering! i fount it to be alot better! but my vocals when i try to record are low. i am using a m-audio mobile pre-amp with a condensor mic. when i turn on the phantom power the mic is loud then drops lower n lower.
is this caused by the settings in the pre amp or adobe audition? i have the inputs n outputs all on ausio so i don't know whats the problem.
ANY SUGGESTIONS?
Sounds like a problem with your preamp's phantom power to me
That was my initial thought. i sent it to m-audio and they sent it back stating all the plug-ins are fine????
i found out how to get the level i need during mixing but i'd still rather have a high wave when speaking into the mic
Some simple (possibly insulting) questions that seem obvious but need to be asked! :) ...
Have you adjusted the preamp gain to achieve your desired input levels?
What kind of peaks / RMS levels are you looking at on your DAW meters (dbfs)?
Is Audition registered and activated properly? You did pay for it right?
As a generalisation you want your input to be averaging at about -18dbfs. Don't try and push things too high on the way in... leave some headroom!
Vocal and mic technique will go a long way towards recording a consistent, high quality vocal track, however you may still want to smooth out peaks and even the whole thing out with a compressor.
-18 LMFAO it's not even touching -21
the answer to your questions are yes yes and yes!
i have my i have my m-audio settings +12 input +12 monitor mix
latency 512 and sample 44.1
i can adjust the level to the vocals in adobe when mixing BUT IS THAT OKAY TO DO THAT? WILL IT DISTORT THE AUDIO IN THE LONG RUN?
I use Audition 3 and raise the vocals like that all the time. I just use a light hiss reduction if that becomes a problem.
I know it's not the best, but as far as compromises go it's not the worst.
I know this is an old thread, but a friend of mine recently purchased one of those units and is having a very similar issue. After about 10-15 minutes, the volume drops off drastically, as if the phantom power fades away or something.
We tried a powered USB hub, but that didn't really seem to make a difference. Next week we're going to try it on a few other computers in order to see if it's a consistent issue or computer related.
One more productive test might be to try an external power supply and bypass the power in the mobile pre. Something like this. You simply put it in-line between the mic and Mobile Pre and it supplies the phantom power. (But set the phantom power in the Mobile Pre to "OFF" when using a second power supply.)
You could also try another condenser mic.
Process-of-elimination will reveal the problem area.
