F
fox929
Hey Guys, hoping someone tech minded can help me out...
I'm using Skype to broadcast from home and elsewhere through a good mic, and quality is relatively good. Sounds clear through the other side and it's to the point where I want to use two microphones. I'm using an Mbox 2 Mini to power everything up.
Input One [1] works fine, that's with the XLR Socket and i've got an RE-20 hooked up to that.
Input Two [2] has its own microphone set up, and it too works at times. However, the other side can only hear Input 1.
Is there a way that allows both inputs to be recognised and sent back to the computer receiving all this? Cause i'm quite stuck.
Basically they can hear the RE-20, but not the other Mic, but I can hear it through the Headphone Jack at the front.
Help would be greatly appreciated!
