sweetbeats
Reel deep thoughts...
So in a moment of mental drift this evening I wondered if anybody has ever adjust their record eq this way:
Record pink noise and monitor off the record head with a spectrum analyzer and tweak away.
At least with my Tascam decks the methodolgy is to record tones over a predetermined range and adjust the response at those tones so the deck is within the specified range (like + or - something or other dB's from 40 ~ 20,000Hz or something like that). So why not just hit it all at once with pink noise and look at the response curve in real time?
Now, I understand that there's a difference between pink and white noise but I'm pretty much convinced of using the latter for bias adjust. I see no reason not to use pink noise for EQ. It may not be textbook but, heck, I see no reason not to try and if your ears are good and you can match source vs off tape, then you've just adjusted your recorder, more or less, to precisely capture complex frequencies, found in music material.
