muttley600
Banned
Thanks for your reply, I never said the neck would bow from storage. I just suggested that strings increase in tension with time. That tension doesnt mean it will bow the neck. Is it agreed strings increase in tension from playing? Is it accepted that old played strings are harder to play and stiffer(more tension)? I wondered if strings kept under tension become stiffer and tighter with time even if they arent played. I have repeatedly have had to loosen my strings on many guitars that were in thier case or hanging on the wall. I am going to start an experiment. I will take an E string, Martin 056 and hang it with a certain amount of weight, 10lbs. I will then see what pitch it is with an acoustic pickup and an Oscilloscope. I will then monitor the pitch and see if it in fact increases with time.
VP
No it not agreed. I have constantly asked you to provide the science behind this claim that refutes the science I posted. This is a case in point and demonstrates exactly how much you don't know about the subject and how much you need to learn. There is no point having an opinion about something when simple physics says other wise. I shall repeat for the benefit of the group.
Strings and their pitch are dependant on three properties. Their mass per unit length, the tension, and the string length. Exactly which one of these properties changes?
Are you suggesting that strings tuned up to pitch work harden to such an extent that the elasticity changes continually? Show me the figures? Show me the research, show me the papers. Show me anything to back up what you claim.
