B
Big Kenny
and I'm the Queen of Sheba
So all you guys think that someone named anass asking for the best $100 mic is serious?
Mic forum raid.
Wanna buy a few cables?
Plus I've read that anything past 20' has a noticeable degredation to the signal.
That's not true. If it were true, why would you need to read about it? You should be able to hear it easily. Any cable effect must vary with the length of the cable. Indeed, cable capacitance does. But 20' is far too short to matter with low-impedance professional microphones.
Try this very simple test: take every cable you have but the shortest and chain them together, plug them into one channel of a stereo preamp. Plug the shortest into the other channel. Connect to a pair of mics. Record a source (preferably at 96kHz), then swap the mics and record again.
HF roll off due to cable capacitance will be readily evident as a 6dB/octave drop above the corner frequency. What is your measured corner frequency (-3dB point)? Is it below 40kHz? How long is your daisy-chained cable?
Can you measure any difference in interference? If so, how are the cable connector shells wired? Terminated to ground or not? For a single cable it usually doesn't matter, because the mic will tie pin 1 to chassis and the preamp should too. But when you chain cables, if the cable doesn't tie pin 1 to chassis then you have a short length of unshielded cable. A minute with a soldering iron will fix that (if you daisy-chain in actual use).
HF rolloff due to cable capacitance will be readily evident as a 6dB/octave drop above the corner frequency. What is your measured corner frequency (-3dB point)? Is it below 40kHz? How long is your daisy-chained cable?
As far as mics, SM58, learn it, love it, and figure out where to go from there based on what you don't love about it. $100 stereo pair for the C2's? I might have to check those out. It might prove useful / sacrificial when recording at sleazy bars or in the rain.
Hey Anass:
One of the others suggested an AKG Perception. I have the AKG Perception 100 and would highly recommend any AKG Perception model as a first microphone. By the time you have recorded one album, you will know what you like and dislike about it and in turn, know what to buy next.
Second choice would be any of these Behringers. B1, C1, & C3.
These are all condenser mics and all have their strengths and weaknesses.
For your instrument, go with the Behringer C2 pencil mics/matched pair. ($79 US) They are about the best deal on any microphone and will serve you well.
I only have 3 XLR cables. One radio shack and two mogami. All 25', so no way to compare / test just yet.
To the OP: Check out the Nady RSM-4 Ribbon Mic. Remove the inner mesh. Very good and "real sounding" for $80. I used to bash on chinese crap, but this mic really surprised me when I borrowed it from a friend. No I have two coming, and I'm going to get rid of the inner mesh, and change out the transformer.
Guys, we need to chill on the newbies. I know there have been a couple of bad newb threads lately, I was in the thick of one of them. I know that after three or six or nine years, some of you are tired of answering the $100 mic question. Just move on and don't post on the thread then. This is a newb-friendly board. Please, let's not have to have us constantly moderate the board to make it safe for newbs.
Thanks.
