muttley600
Banned
I haven't changed my bass straings in 7 years. Are they still good?
No, burn the bass and get an acoustic for them. They should be good for another seven years then.
But acoustic guitars suck.![]()
More than bass's.![]()
Except 5 string bass's of course.
The powder absorbs all the gunk and it dissapates it into thin air!No, I won't just let it be because it is both very bad advice and also flawed.
The powder thing is obvious to even a kid in kindergarten. Tell us how powder stops your fingers sweating and makes dirt dissapear?
The tension thing was obvious to Pythagoras around 450BC. He derived (quite correctly) that frequency was directly linked to the unit mass of the string, the length of the string and the tension of the string. You change one you change the others.
Your neck relief cannot change unless the tension in the string increases. It does not unless you change either the mass per unit length of the string or the pitch. If it does your strings are either changing in mass on their own (something even quantum physicists haven't suggested is possible) or more likely you are playing out of tune or imagining it.
Here is an explanation of the fixed properties of vibrating strings. Learn it and understand it before you reply and then show me some evidence that there is a molecular change in the material properties of the string that alter their behaviour.
Simple maths and physics does not cheat on us.
VP
5-string basses are on the same high level of suckage as 7-string elctrics and all acoustic guitars.
Put some talcum powder on it.I have an extra finger for sale but its soiled....
I hate them too so they must be superb.![]()
YES! D'addario was the other brand a guy at work recommended. Totally forgot.
Muttley IS right, though - unwound strings are going to sound consistently better, even though you have to change them more often because they don't last as long.
On one hand, muttley is basically right - any time you coat a string in something, it will at least slightly effect the way the strings vibrate. If pure tone is what you're after, then coated strings are probably not the best way to go.
On the other, I use Elixir nanowebs. I'm mostly an electric player, and rarely pick up my acoustic more than 3-4 times a month. My experience has been uncoated strings generally have a shelf life of a couple weeks at most for even light play, so for me the slight attenuation of the high end you get with the Gore-tex coating is totally worth the fact I don't have to throw a new set of strings on my acoustic every third time I play it. It's a trade-off, but one that makes sense for my specific playing situation. Your mileage of course may vary.
As far as the "hard to play" bit, acoustic strings are just traditionally heavier than electrics. An "extra light" set of acoustic strings will still be .11 or .12 gauge. The heavier strings tend to be a little more compressed and even sounding which for better or worse is part of the "sound" of an acoustic. I forget if I play 12's or 13's, but either way it's a question of just sucking it up, getting used to it, and waiting for your calluses to harden up again.
Ignore Victory Pete, btw - the advice isn't as completely crazy as his original suggestion to apply talcum powder directly to the fretboard to keep it clean, but I'd still be worried about getting powder in the pores of your fretboard.
I assume you mean "uncoated".
It is just a preference mind as I've always said. To my ears coated strings sound too squeaky and bright new, settle down for a day and then sound squeaky and dull for the rest of their natural life. I also haven't noticed a significant extended life when it comes to intonation problems which is normally my trigger for replacing strings. Those are just my observations mind and everyone has their preference.
