G
ggunn
Crystal Flavolian
At what cutoff frequency?Try an integrating (first-order, low-pass) filter. It will roll off the sound at 6 dB/octave.
With the cutoff frequency below the fundamental of the lowest note, it would attenuate the entire range of the instrument at 6 dB/octave. If the cutoff freq were set at the lowest E, then the fundamental of an E at the 12th fret on the first string would be down 18dB. Is that what you are going for? It's hard for me to believe that such a thing would sound good.I typically like to have the cutoff slightly below the fundamental of the lowest note. That way it's 6 dB/octave pretty much all the way up. The values I quoted are designed for guitar in standard tuning with a low E and produce a cutoff = 1/(2*pi*R*C) of 72 Hz. That's a tad below the fundamental of the open E string, but that's OK, since the full slope doesn't develop until somewhat above the cutoff frequency. You could step up to the next value of cap and that would lower the cutoff, probably to about 50 Hz, which is also an OK choice for guitar.
Going lower mainly serves to reduce level and require more makeup gain. However, it also extends the sensitivity compensation down into range below the lowest fundamental. It's up to you whether that's a good thing. On bass, I've used as low as 16 Hz and it works fine. 32 Hz works fine, too, and requires 6 dB less makeup gain.
The convenient way to tinker is to use a potentiometer, rather than a fixed resistor. At full value you have the lowest cutoff. By reducing the resistance across the pot, you raise the frequency until at zero resistance you have raised the cutoff all the way up and have no filtering. I believe this is the way Alembic tone controls work.
By the way, this question inspired me to play my Ovation a bunch last night. I lied... it sounds WAY better through the filter. Better than I remembered. Really no brittleness at all. That is with the "pre-EQ" setting turned off, just the plain pickup signal. Very natural on fingerstyle. I actually have to tone the bass end down a tad when playing with a pick, but it sounds very good in the upper register. In fact, it's a tone that works great for recording on its own. I'm sure it would also sound good in support of the acoustic tone.
Yes, you have done the math correctly. There's really only one way to know for sure what it sounds like, and it's up to you to decide if it sounds good!I use this type of system every time I play and it sounds great to me.
There is a basic element of the physics of magnetic guitar pickups that explains why this works so well on electric bass and guitar with magnetic pickups: they use inductively-coupled pickups with a sensitivity that rises at 6 dB/octave, just like the repro (playback) head on a magnetic tape recorder (where the tape playback eq circuit has just this kind of 6 dB/octave integrating filter to compensate). I usually mix in a little of the original, unfiltered tone on a mag pickup, because the electrical properties of the pickup and cable already roll the high end off over the resonance, which is typically somewhere around 5K.
As far as these piezo pickups are concerned, I'm still studying the (less-familiar) physics of that, so I'm not yet sure what it is about them that causes that brittle sound. All I know is that when I use the same filtering I use on mag pickups, I get a good sound. There must not be any high end roll off on the piezo (it does have a built-in preamp, which helps), because all I need is the filtered tone. No need to add in a touch of the unfiltered tone to hold up the high end the way I do with mag pickups.
Have fun with it!
Cheers,
Otto
It has to do with the material properties of the piezo element itself. Specifically how they report the attack and decay at specific amplitudes of vibration and the way in which different higher partials are either accentuated or cut off at those amplitudes.
None of this has anything directly to do with resonance which of and in itself is meaningless. Can you explain what you mean when you use the term?
I'm puzzled, too. You'd be attenuating the entire range of the instrument's response, at 6dB/octave.With the cutoff frequency below the fundamental of the lowest note, it would attenuate the entire range of the instrument at 6 dB/octave. If the cutoff freq were set at the lowest E, then the fundamental of an E at the 12th fret on the first string would be down 18dB. Is that what you are going for? It's hard for me to believe that such a thing would sound good.
Does that clear it up?
Otto
No not really, I ask because it's one term that consistently gets used (incorrectly) by my students. They use it often without any clear understanding of what resonance actually means within the field of physics and specifically in musical acoustics. Other times it is used by some wishing to blind an argument when they don't have the faculty to construct a clear explanation.
I'm not accusing you of either by the way. At least not yet.
Resonance refers only to the ability of a material to vibrate or oscillate more freely at specific frequencies owing to it's physical properties...
Resonance is observed primarily in one of four models or systems. Mechanical, acoustic, optical and electrical. They all observe the same boundaries and relate to each other. Also with the absence of electro magnetic induction and resulting impedance in a piezo element transducer I fail to see how the physics applies here or am I missing something?
I wasn't questioning that you personally like the way the filter works on your guitar. I was asking you how resonance would be relevant in a piezo system and hoping you would explain how your model does anything other than duplicate the process already being undertaken by other components in your signal chain. What you describe just seems to me to be a very crude filter. One that in my "limited" experience as a guitar builder and acoustician would do little to enhance the brittle response of a piezo transducer. Forgive my curiosity.I've now said, more than once, just in this thread, that I am not talking about the physics of piezo pickups. Here's a quote from my previous post:
"As I said, I just tried it out on the piezo pickup and it sounds great. I don't know what the physics would indicate is an optimal compensating system for the piezos. I just know that this works really well. "
I was just explaining why I started using this system on mag pickups, which IS based on fundamental principles of operation of magnetic pickups. That it also helps give me a better, more natural tone on the piezo is just a happy coincidence, as far as I know. I make no claims that it is optimal for piezos or based on basic principles of physics for piezo pickups, only that it sounds good.
If anyone wants to try it out, they can and if they have questions, I'll try to help. I was just trying to help out the OP with the problem he mentioned:
"I'm trying to find a way to lessen that "brittle" sound in live performance..."
and I happen to know that this filter answers that same concern in a way I happen to like.
Cheers,
Otto
Actually, I hate the sound of piezo pickups - they are the most unnatural sounding things. (Reminds me of Douglas Adam's description of the Nutrimatics Drink Dispenser on the Heart of Gold - to paraphrase, when you asked it to make a cup of tea, it made a liquid that was almost, but not quite, entirely unlike tea.Indeed, you will. 6dB/octave is a gradual filter, however. If you already like the brittle tone of your piezo pickup, you may not like the filtered tone. It does, however, sound much more like a real guitar to my ears when using the filter! Words will not decide the question. Only listening can. Try it! The great part is that it is so cheap and easy to try it out.![]()
I wasn't questioning that you personally like the way the filter works on your guitar. I was asking you how resonance would be relevant in a piezo system and hoping you would explain how your model does anything other than duplicate the process already being undertaken by other components in your signal chain. What you describe just seems to me to be a very crude filter. One that in my "limited" experience as a guitar builder and acoustician would do little to enhance the brittle response of a piezo transducer. Forgive my curiosity.![]()
Actually, I hate the sound of piezo pickups - they are the most unnatural sounding things. (Reminds me of Douglas Adam's description of the Nutrimatics Drink Dispenser on the Heart of Gold - to paraphrase, when you asked it to make a cup of tea, it made a liquid that was almost, but not quite, entirely unlike tea.)
Hell, maybe a 6dB low pass is what they need to make 'em sound decent. I just avoid them entirely.
Oh, for sure. Just like any other sound, it is what it is and in the end it's just another tool in the toolbox. I have a hell of a time getting my Martin to mic up for a mix because it's so boomy, so I can't exactly pontificate on the superiority of a purely acoustic sound.I love that line.
The one caveat I'll add, is while they sound almost, but not quite, entirely unlike an acoustic guitar, sometimes that sound actually works very well for a part.
