etanercept
This is my first post. I'm new to recording, so let me give you some back ground. If it's SRV, Clapton, and Hendrix I can play it. Please don't think I'm bragging, I live for the guitar and that's all I ever wanted to do, and I've been doing it for about 30 years. Spend enough time on it and anybody can do it. With that being said, I figured I'd record some and impress my freinds. I got the tools - (1) Sonar 8 Producers Edition (2) A screaming Quad 4 AMD with 8 gigs of ram (3) Sonar Firebox (4) M-Audio Studiophile BX5a Deluxe Monitors and (5) more VST plugins you can shake a stick at! I'm doing drum tracks, bass track, two to four guitar tracks, and a vocal. I put high pass filters on everything except the kick drum/toms and bass. I cut all frequency below 100hz on the bass and boost the kick around 120hz for 2 or 3 db. When I mix it down it sounds great in my band room. Everywhere else the bass is way too much and muddy. When I go back and try to fix the mix, the bass level that finally makes the rest of the world sound OK (I did say I was just begining) is almost non-exsistant in my monotors and still muddy on other systems. I'm not looking for the magic bullet, I just would like some input as to a path to some solutions. It seems I read alot about folks having too little bass problems in their monitor mix, but not the other way around. I could be wrong. I'm thinking room correction software. Any input would be appreciated.
the room is one of them things that should be tuned, just like you tune your guit-fiddles. Not only for tracking with mics but mixing especially.
