B
Beck
Guest
I've had a dog in this fight since 1989, so please take your time. It's not that easy as it seems at first look. First of all I would narrow your paper to the two technologies as recording mediums. For example, MIDI is neither digital nor analog. I was using MIDI when it first came out, long before affordable digital, and all synchronization methods before that were deigned for video and audiotape in the beginning. MIDI is not digital per se. It's a control method and can be used with tape, analog synths and analog consoles.
A couple comments on some of your points:
One can also say of analog, “Do things digital can’t.” And again using digital synths/samplers isn’t a problem with most people that prefer tape for recording. My studio is full of digital gear, but I prefer recording to tape. By pitting everything digital against analog tape you are in a sense creating a debate that really doesn’t exist in the music world. You could throw in digital TV for good measure. See what I mean about narrowing down the argument?
The fixing/manipulating with things like pitch correction is a hot topic. You won’t find a consensus that it’s a good thing. Many see it as very destructive to the artistic process. But we could pitch correct before digital. It just wasn't so handy as to be so easily abused.
We were doing this in the analog days by sending tapes through snail mail, albeit slower. Bands, for example Van Halen, would create entire albums by recording one member’s part in a studio in New York and another member’s part at a studio in LA. Yes it is faster and more convenient now, but the concept is not new. Tracking and mastering were done in different studios as often if not more than everything being done in one studio. The emergence of the home studio changed this more than the advent of digital.
Not necessarily because now you’re getting into the whole area of mixing and mastering, which requires in depth knowledge of acoustics, psychoacoustics, EQ, blending, masking, separation, etc. It is still a gradual process. That hasn’t changed.
Always debatable. The idea that digital sampling/recording is benign is a myth. Digital imparts its own artifacts that many of us find objectionable. But you don’t even have to invite an analog advocate to the debate. Just start following the innumerable threads on many forums where digital advocates are debating with each other over converters, bit depths and sampling rates. Analog isn’t even on their radar (no pun).
This is one of my all time favorites.
I have several analog machines, but two I’ve owned for 20 and 23 years. They still function exactly the same as they did when I bought them. The maintenance time and cost have been a drop in the bucket compared to the countless PC’s/DAWs I’ve gone through in the same time period.
I also worked in a TV studio and later a commercial recording studio in my younger days. I’ve been a computer/network consultant for about 12 years, so I know the true total cost of ownership of the devices and mediums in question.
I don’t even remember all the software and computer hardware I’ve gone through in my own home studio, but here’s a quick summery of my experience.
Buy Alesis ADAT after reading breathless review in Electronic Musician Mag
ADAT has life span of typical VCR
Throw away Alesis ADAT
Buy PC and software
Microsoft OS bugs
Microsoft releases fix
Fix introduces new bug
Microsoft releases fix V2
Program has compatibility problem
On phone with software vender
Vender releases fix
Blue screen
Virus
Crash Boom Bang!
Reinstall OS and all programs
Hard drive crash… need replacement
Bad RAM… replace
Processor burns up because fan failed… replace with faster one for good measure
New software released… makes old hardware obsolete
Need new PC
New OS released… conflicts with new recording software/hardware
On phone with hardware vendor… can only use program with Intel Board
Buy new motherboard
Defrag on a schedule
Scan for viruses on a schedule
Periodically vacuum out inside of PC as routine maintenance
Case fan stops working
Video card dies… need replaced
Monitor color goes funky… need new monitor
Hard drive too small… need bigger, faster one
Reinstall or transfer contents of old drive to new
Chorus
Bridge
Repeat
Oh wait, 16/44.1 isn’t good enough after all this time anyway… lets do 20-bit or 20/48
Not so fast… if you don’t have 24/96 it just won’t sound “accurate.”
But what about the 16/44.1 “Perfect sound forever” thing from Sony? I feel violated
Buy new PC to support new OS, new hardware and recording software
New version of recording software doesn’t work well with new OS
Discard old software and try something else you have to learn all over again
Or go back to previous more stable OS and keep old software
Reel-to-reel deck sits in corner and laughs at you through the whole thing and starts taunting you in your dreams… “Timothy… Timothy… but I thought you said Windows 95 SR2 was the OS of the gods and that a 266 MHz processor was like OMG!… HA HA HA… you fool!”
Seriously, the biggest mistake people make is not factoring in the cost of PC hardware, software and all the computer maintenance into the studio budget. Every PC, OS and program issue is an issue for the digital format. If you have a self-contained digital recorder you won’t have all the PC issues, but they have their own issues, bugs. Limitations, etc.
Perhaps in the short term, but then a gravel road is more cost effective than asphalt, but how’s the ride?
Tim
Do things analog cant
Create effects not possible in analog
Record instruments/sounds not available to you (samplers)
Fix, improve, manipulate musician’s performance (tuning, pitch manipulation, timing correction)
MIDI (do things humans can’t, have perfect performances)
Do things better than analog
Share data between multiple users at same time (sending pro tools sessions, tracking one place mixing at another)
More precise idea of final product though all stages (sound)
Technically superior/robust
Doesn’t degrade (sound quality)
Higher sound quality (technical)
Analog equipment requires more maintenance, care
Buy PC and software
Microsoft OS bugs
Vender releases fix
Blue screen
Virus
Crash Boom Bang!
Bad RAM… replace
Need new PC
Buy new motherboard
Chorus
Bridge
Repeat
More Opportunistic
Much more cost effective
Tim
