..to
Tim Beck!
Heh heh.
On subject of "business".
One thing I'd need to clear up a bit for the "record" ... In my mind "business" (in general) is NOT a negative (pejorative) term.
Business = Good! (in general, that is).
Then there are all kind of businesses, but that would be a separate topic.
Honestly, I personally think that MRL tapes are too cheap. And I am not kidding. If I was doing what they do - I would not do this stuff for nothing and would not do this for a little nor for just "O.K. cash".
And when "good guys" run a business - even MORE power to them and it's all good for everyone at the end.
But it is what it is.
On subject of standards
Tim! You see we are "dealing" with
speed here, distance unit per time unit that is.
So?
The only two
standards are needed:
1. 1 inch (or meter) (distance unit)
2. 1 sec (time unit)
Last time I've checked Magneting Rec. Lab kind of was not in
Time and Space business... or did I miss something ? heh heh
You see ,
when you use MRL "speed calibration" tape, you are not matching speed by measuring the actual speed of tape on your machine, but instead you are "matching" speed of tape on your machine to speed of tape on MRL's machine. Which is fine. It makes practical sense at the end. Or does it?
At the end it's not about 15ips, but insead, it's all about WhatEver-MRL-machine-ips.
As long as we
ALL agree that MRL's machine is STANDARD, then we are all happy cats ..heh heh heh , as all we really asking for is to get "standardised" .
Or you can do it without MRL, all you need to do is to find the way to actually measure the "actual" speed of tape on your deck.
So, again, Ethan's "idea" is all about figuring out the period of recorded tone(or puls) on tape. If you know the distance between periodic waves/pulses on tape (or total amount of periodic waves/pulses per known length of tape), then your frequency counter can be used as speedometer.
