When you set the master fader to unity gain, do you mean the level indicator should never exceed 0db(i.e. going into yellow/red zone) or the fader itself should appear be positioned at the 0db marking? Do I sound confused, well yes I am.
Bristol Posse got it right, but just to try and make sure I address the probable confusion with the terminology, "unity gain" refers specifically to the physical "0" position on the fader control itself, somewhere around 2/3rds to 3/4ers of the way up the fader. "Unity gain" simply means no signal boost, no signal cut; you're passing the signal through that fader without changing the volume at that point.
When you do that, what the signal reads on the meter at that point will be totally dependent on the strength of the signal going into the fader since the unity gain setting on that fader won't be changing the volume. By setting the master bus to unity gain, this ensures you're looking on the maim meters at the actual mix volume and you can that way monitor your mix levels as you mix.
I love this! Next mix I do, I'm giving this a go. Seems a hell of a lot easier than trying to nudge everything channel down the exact same amount when it is tracked too hot.
Exactly. I found myself often having to pull tracks down during mixing, almost always at least one track.
Pulling down the channel volume (input/trim volume, track fader, etc.) doesn't work as well for me, because that sets a maximum track volume above which one cannot automate. If you want to the go above that, you have to change the track volume and then adjust the entire automation track in order to keep the track at the same relative mix level, which is a pain in the ass.
So I figured that I'd just use the man track volume to set the maximum track level, and then set the automation down a few dB on each track as starting levels, leaving me some "headroom" in the automation tracks to be able to boost the track up to as high as maximum track volume if I wished for certain mix points. Think of the volume automation like if it were a fader in and of itself, and you're starting with the fader set most but not all the way up (kind of like a unity gain setting, in a way).
This allows for plenty of flexibility in actual mixing - i.e. fader jockeying via automation - while keeping the amount of global track re-tweaking to a practical minimum .
But the unexpected beauty to this technique, Chibi, which I didn't plan for, but which works out nicely, is that the mix levels seem to just naturally work themselves out that way. For a typical medium density rock or pop mix, I'll typically wind up with a final mix with an RMS within a couple of dB of my A/D converter calibration levels, pretty much like god (and the AES) intended it
![Wink ;) ;)](/images/smilies/wink.gif)
, without having to take the master levels off of unity gain.
G.
