Well, Tom, who the hell knows? My studio was originally conceived to record an album, which was layered using overdub staff flown in from all over the country. What this meant to me was that I wasn't often recording a lot of tracks at once. On the other hand, I had to get it right, because my lead guitarist was at the other end of the country, in Portland, Oregon, and multiple overdub sessions were not a realistic option. The same was true of the backing vocalists, etc. I learned to love the Avalon not so much for what it did, but what it *didn't* do. It didn't make noise. It didn't clip-ever. I wasn't trying to mix the thing, or master it. I was trying to track it. That meant that if I could send the mixing engineer a pristine set of tracks, recorded with the right mics in a good room, he could spend his time mixing, instead of doing noise reduction, and trying to compensate for bad takes, bad EQ, and bad FX.
So I didn't spend a lot of my money on compressors, FX, etc. What I needed was 2 matched channels with a ton of gain, lots of headroom, and no noise. I also needed a top-notch bass DI. The Avalon has never let me down on any of those points. OK, then I realized drums were going to take at least 2 more channels. I bought the twinQ because I couldn't afford another Avalon. I later upgraded it to the new twinQ, which in many ways, is a better match for the Avalon. With the "iron" switch engaged, which uses transformers, it is quite similar to the Avalon. I found the compressor useful, with light compression, so I added an RNC to the Avalon's basic signal chain to get some available light compression, and struggled a bit with how to patch up the Avalon's XLR outs to the RNC with no available inserts. I worked it out.
Meanwhile, I was working on a micro-studio for remote recording, and as a scratchpad for the album project when I was on the road, based on a KORG PXR4 Pandora. It needed a small inexpensive preamp. Based on a lot of recommendations on this board, I got a DMP-3. In the studio, it turned out to be 2 more auxiliary channels for expanded drum mic'ing, and a non-critical preamp for a talkback mic.
Then I got involved in a commercial project, doing a Science Fiction radio play, which sometimes involved a whole lot of open dynamic mics. The core had been upgraded to a Digi002 for better AD conversion, so I started looking for an 8 channel pre with lightpipe out, and the project didn't require particularly great preamps, just a lot of channels by lightpipe. So I got a Behringer ADA8000, which did the job just fine, and for what it's worth, it expanded my available simultaneous inputs to 18. That's the 002's own pres 1-4, the Avalon 5-6, DMP-3 7-8, the twinQ by S/PDIF 9-10, and the ADA8000 11-18. But where do things really go? To the Avalon, just like they always did, and to the twinQ because I'm tracking drums, or I just want the sound of agressive optical compression, usually on vocals. And, by this time I had acquired enough mics, cables, mic stands, headphone distribution, etc. that in some imaginable situation, I might actually be able to use all 18 simultaneous ins! Woo Hoo! But what am I more likely doing? - recording in stereo with the Avalon and a pair of Neumanns.
You see, the point is this, Omtayslick- I didn't do anything like what you said. I didn't work my way up that long ladder from Behringer to Avalon, from SM57 to Neumann. Just the reverse. I planned out my studio with a dedicated budget to do a specific job, and acquired my best guess of the top-notch signal chain to do it. Then, as I began to do small commercial projects with a variety of needs, the need for more simultaneous inputs drove me to lower level gear, because that dedicated budget wouldn't support 18 channels of Avalon and Neumann. At least, by the time that happened, I had learned enough to buy cheap gear that could do what I needed it to, and to not expect it to do what it can't. I'm still doing it, I'm still having fun, and I expect that fracking Avalon will outlive me, in spite of my best efforts to kill it. Hell, I'm about to jack a Behringer dynamic into it. That may actually kill it with shame! Or- it may sound better than any one of us would have thought. More to come.-Richie
BTW, you're not Gracie's brother are you? I think she has a brother named Tom...
