[QUOTEHello, Ive began building a vocal booth in my room.[/QUOTE]
Hi, welcome to the board. Ok, when you say you are "building a vocal booth" in your "room"...what do you mean by "building". In other words, are you "building a FREESTANDING NEW STRUCTURE" within an existing room? Or are you MODIFYING the existing walls of this room to improve the TRANSMISSION LOSS of the existing walls, or what?
The walls have two layers of beams.. as : sheetrock-beam-plywood-beam- sheetrock. This is about 9 inches thick..
Is this the way the walls are EXISTING, or are you ADDING something(ie second set of studs and drywall or plywood? Please be clear. Have you already done this or is this just a plan? If it is JUST A PLAN...HOLD YOUR HORSES!!! You do NOT want to build it this way. Unless this wall is ALREADY built this way, you would be making a very big mistake, as this would be whats known as a TRIPLE LEAF, which you do NOT WANT!
And also..when you say "This is about 9 inches thick..", is this just the plan, or it actually exists already with a dimension of "about 9"?
If it already exists, are the studs in both walls 2x4, and if so, are both sets of studs touching the PLYWOOD shiething in the middle of these two walls?
Is this what it looks like?
If so, I have some things to tell you, so please get back to me if you want REAL help. Thanx
fitZ
