multiple tracks?
  • Thread starter Thread starter pinkieandtherev
P
pinkieandtherev
OK...so I've had my Yamaha MW12 (with Cubase LE) for awhile. Until now, i've only recorded one or two tracks at a time tops. My old system downstairs (1.2 Ghz, 256 MB RAM, USB 1.1) only shows 2 inputs (USB Audio Codec 1 and 2). Yes, I know, that old system is pitifully slow and underpowered, but for most of what I'm doing, recording two tracks tops at a time, and turning off extraneous tracks while recording new ones, it handles OK.
The Yamaha has 6 XLR inputs. I'd like to be able to mic up the entire drum kit and individually track everything. If I take the time to setup my more powerful system (3.0 GHz, 2 GB RAM, USB 2.0), will Cubase LE allow me to record 6 tracks at once instead of only two? I can't seem to find a straight answer...can I DO that with this mixer, or am I limited to the stereo mixdown?
That mixer will only send a 2-channel stereo mix to the computer.
If you are wanting a multiple-channel interface, here's a good guide and tested suggestions: http://www.tweakheadz.com/soundcards_for_the_home_studio.htm
Thanks Tim...this is exactly what i needed to know before I spent the time lugging everything downstairs. SOOO...what I really have is a 12-channel (6-XLR) mixer that will output its stereo mix out to the computer via USB. 'Tis OK...I guess that just means I have to get it right BEFORE i record it...no "fixing it in post." :D
Yes. You can record up to 8 tracks simultaneously with Cubase LE.
The OP still can't record six tracks simultaneously using the Yamaha because it only outputs stereo via usb.
That's true. But one of his questions was can Cubase LE record 6 tracks. I figured he would like to know that it could. :)
