A
aireq
I'm a DJ and I'm trying to record all my vinyl to my computer so I can use CDs instead. But I'm having a number of issues
Here's the equipment I'm using
Technics 1200-M3D Turntable,
Tascam X-9 DJ Mixer
M-Audio 2496 Sound Card
Now for the first issue. I have the turntable connected to PHONO 1 on my mixer. I start playing a record and adjust the trim for that channel so that the level is just barely below 0 db (not clipping). My mixer has a menu option to bypass the master fade so I set it up that way for recording. Then I hook up the mixer to my sound card through SPDIF (Coax connection). As the record is playing the meter on the mixer says the signal is just below 0 db, but the M-Audio Detal control panel meter on my computer says the signal is a lot lower at around -10 db. Wavelab's meter show the same thing. What's going on here? Should I just turn up the trim on the DJ mixer until the soundcard meter shows the right level and ignore that the mixer is showing +10 dB? I don't see any option anywhere to adjust the input level at my soundcard?
I should also mention that the meter for program 2 on my mixer is not functioning. I'm using program 1, and audibly everything seems ok with it, but the program 2 meter just doesn't show anything. This might be related, or it might not be. BUt I thought I mentioned it.
OK the next issue. I go ahead and set the trim on my mixer so it's showing +10 DB and my sound card and wavelab are showing about -3 db. On my sound card control panel I reroute the SPDIF in to my speakers so I can monitor the recording. Everything sounds ok, and I go ahead and record the record to a 44.1khz/16bit WAV file. As it's recording the song sounds fine.
After the recording finishes and I try to play it back the recording is full of static. There are regular loud pops all through out the recording that I did not hear while the recording was being made. Here's what part of the waveform looks like in Wavelab. The red arrows mark some of the pops. I've also tried another recording software (Audacity) and got the same static and pops in the recording. Does anyone have any idea what is going on?
Also, I get the same issue with static and inconsistent metering using RCA instead the SPDIIF connection. So it would seem it's some issue with my sound card?
Tascam X-9 DJ Mixer
