S
smallhands
What are the pros and cons of PCI vs. USB interfaces? Also, I could use some feedback on what brands are the best.
PCI is way faster. With USB, you can typically only record 2 channels at a time. There are a handful of exceptions, but I haven't heard anyone raving about em. PCI interfaces will allow you to record as many channels at once as you want, for all practical purposes.
Firewire would be the way to go imo, there's a ton of great fw interfaces out there. You could use the PCI slot for a firewire card if you don't have a firewire port. Then you could hook up your video camera, external hard drives, all kinds of other fun things too!
Like suprstar said firewire is the best route to go. If you don't have a firewire port then get this card. It's the card you want as it has the T1 chipset which is preferred.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815150074
Depending on how many inputs you want there's a lot of interfaces that can suggested.
I have that firewire card and have had zero problems with it.
