D
doulos
ok so I'm extremely broke right now and more importantly have limited time. I have a untreated room. I want to revamp the whole room and get some acoustic treatment in place. I can only get rigid fibrglass if i pay 30 bucks in shipping on every 6 panels and to me thats to much on my budget so here goes
the room is 13 1/2 long by 11 1/2 wide I have 2 doors on the right side of the room. main door and closet on the far front and back walls. Dead center on the left side of the room I have a window 39 wide by 35 high and I have a celing fan in the center of the room. I don't know how to measure the room. do I remove everything? do I leave the mix position alone? not sure how to do it
I have a db meter roomeq wizard and a rode nt5 microphone I can use
ok now on to the bass trap looking at the Absorption Coefficients it gets confusing 6 inch 703 is 1.19 at 125hz and Unfaced 12" r-19 pink fiberglass on the wall is 1.14 at 125hz here is where im getting confused
what size is the r-19 thats measured or does it matter?
another question can I compress the r19 from 12 inches to 6 or even 4 without ruining the acoustic properties of the material? and 2 more and ill be done
does it have to be r19 or can i use r30? will faced or unfaced matter?
and the main question If I build a 12 inch thick r-19 fiberglass panel compressed down to 6 or 4 inch wood frame 2 foot wide by 4 foot long will it work similar to a 6 inch 703 panel for a bass trap?
