Erockrazor
I mix in (2x) real-time
You should post a demo of the best you can do. Then we can more directly comment on the actual sounds youre dealing with. A popular technique is to put a cut in the eq around the vocal focus in the opposing tracks.
So, put an eq on those huge guitars and cut out maybe 3-6 in the 2k, 3k range. Then maybe even boost your vocal track in that range by a few db. See if this makes any noticeable difference.
With EQ'ing there is an important aspect to look at called masking. Masking occurs when two different sources are occupying the same frequency. The louder one will really drain out the lower one (aka masking). This is a reason why I suggested to sculpt the mix around that range. You will make room for that vocal and the guitar and vocal wont be competing for the same space in the spectrum.
And don't trick yourself into thinking that your guitars don't sound big when on solo. Do this and listen to the mix, not the solo instruments. A lot of eq'ing is figuring out how the instruments are interacting with one another.
Also don't be afraid to use a low cut filter on the vocals. For me this often helps clear things up along with many other instruments. I'm done rambling.
Good luck, Eric
Good luck, Eric
