altitude909
Best Advice Ever: RTFM
I need a new one (SATA, no more the .5 T) and it has been a bit so I was hoping on some recommendations/input
They all suck. Between myself and my friends, we've lost drives by every single drive manufacturer within the last two years. They are orders of magnitude less reliable than drives built five years ago.
Whatever you buy, buy a second one that's at least twice as big and back up the entire content of the small drive to the large drive religiously every week. Once the larger drive is full of backups, each time you back up, delete the oldest existing backup or two to make room.
Average drive lifespan for me is about 9-10 months of regular use, spread across a wide range of machines, both desktop and laptop. That's terrifying to say the least.
Yeah I was reading about the WD caviar - both green and black - and they were both pretty reliable harddrives. The green wasn't thatt fast when it cames to read/write but it wll save some power (hence its name). and the black was meant moreso for performance.
If you really want to save energy turn off the machine when you're not using it
you'ld think this was the case ... though in reality it uses very little current at rest...
i've got three seagates... with the 32M onboard buffer... five year warrantee is hard to beat...
Samsung have pretty high failure rates comparitively speaking
Seagate Baracuda and WD Caviars are pretty solid performers in the 7200rpm range (Seagates can also be had with a 32MB cache although they run a little hotter than WD.
+1
I've never had any problems with either of these drives. I think the high failure rate has to do with the user using them more then the actual drive.
Nope. Even the retards on this board can't break a hard drive simply by using it. For the most part, drives die, or they don't. And I mean individual drives, not particular brands. Except for one, apparently.
Check out Google's hard drive study for some interesting stats. They use millions of drives, and did a study of 100,000 drives that failed. That kind of number actually means something, unlike reading on a message board that "hey, I have one of those, it's great" or "those suck, I had one die." That kind of crap is totally meaningless.
I recommend Samsung Spinpoint F1 drives. Added another TB (in the form of 2x 500gb F1s) to my computer a few months ago and they've been perfect. Very speedy!
Not quite true. Impropper control of: dust management on drives with exposed platters, Vibration damping, Proper cooling and airflow can shorten drive life as can over handling droping the drive or bumping the tower hard and not using an adequate or badly inefficient PSU. Never turning off your PC will also shorten the useful life of your drive (as you burn up hours of drive spooling with no use)
Au contraire. In my experience, what shortens the life of disks most severely is the constant power cycling of the drive spindle and parking of the heads associated with spinning the drive down. If you want to truly maximize the drive life, disable all power management and leave the machine running 24x7. I still have drives running after well over a decade that were treated in this way, and that's not at all uncommon. In particular, parking heads puts a lot of stress on the heads and head arms.
Read this:
http://68kmla.net/forums/viewtopic.php?p=78086&sid=d922cfbb249658ba7725c983df64632c#78205
Cosigned. I have a half dozen 2 gig samsungs that are over a decade old, all are in 24/7 win2k data loggers. My raptor that just died was purchased in 2003
