W
wmtunate
I'm in Nashville. Still waiting on my 81s though.
as if on cue, my invoice just showed up on my console.
I've replaced some of the little 100uF caps with a mixture of 1,000uF and 2,200uF caps and I'm in the process of star grounding all of the minus sides of those caps. The ground is greatly diminished.
Thanks for the clarification -- I actually knew what you meantUgh. Make that "the hum is greatly diminished" or "the ground potential is greatly diminished". Must have been typing late at night.![]()
-- was the mixture of 1000 and 2,200 values because that's what you had on hand? Would all 1000s have worked?Crazydoc, if you've done the transistor swap and shielded the inductors and you still have hum, I suspect your remaining hum is caused by poor grounding, particularly in boards 3, 4, and 5.
On each board, there's a filter cap between the 24V rail (labeled 24v+)and the 24V ground (labeled 24vdi). Solder a heavy gauge wire to the - side of that cap (being careful not to short it to the other side) and put a crimp-on wire spade on the other end. Do this for each board. Unscrew one screw for each board and shove the wire spade under it and screw it back down. Odds are, adding a ground wire to boards 3 and 4 would be sufficient by itself, but it won't hurt to do this to all of the boards.
For additional ground improvement, if needed, you can wire up a series of short wires with crimp-on wire spades on both ends to go between each board. Finally, add a longer one to the back right screw on the power supply. That said, I doubt that last part is really necessary.
It's an easy hack, so it is certainly worth trying to see if it finishes off your hum.
[subscribe...]So now I've installed sockets for the mic preamp transistors 1Q1 and 1Q2 and am awaiting arrival (not until Monday, unfortunately), of 100 each of 3 types of low noise transistors, (among them more BC184C's), so I can go through them and cherry pick the lowest noise ones for the circuit to see if that improves the high gain hash.
Thanks for the clarification -- I actually knew what you meant-- was the mixture of 1000 and 2,200 values because that's what you had on hand? Would all 1000s have worked?
Anyone who wants two 1081's for $320 do 3 things [pre's haven't left chances warehouse yet]
1.pm me
2.get a hold of chance [i've tried emailing but have not heard back]
3.transfer me the funds
)(I'm sure I'm having more fun trying to fix these than I ever will using them.)
Chance - Are you still accepting virtual check payments? I tried to pay my shipping invoice on Thursday, 01/29/09, and after I submitted my virtual check info I got an error screen. But I also received a payment confirmation email immediately saying that my order will be processed, along with an order number.
My shipping invoice still shows "not paid" and "not shipped" in the user control panel and no money has been taken out of my bank account yet. Do I need to pay you again for the shipping?
