Building Dedicated Reaper Box -- Suggestions?
  • Thread starter Thread starter bongolation
bongolation
bongolation
With luck, tomorrow I'll probably get a new motherboard/CPU at Fry's and build a dedicated Reaper box.
I'm assuming that by 2009 there shouldn't be much issue with hardware, but I thought I'd check for known issues with chipsets, etc. I'm planning on AMD Quad-Core, XP, and whatever motherboard Fry's has on sale.
Thanks for any thoughts on this!
dice 2
as far as i know any PC will work (as long as it is powerful enough)
but there are know issues with dice 2 (if you are going to use firewire)
dice 2 is a chipset for some firewire interfaces
other than that reaper is pretty compatible.
**not subscribing to this thread since that is all i know on this matter**
-mike-
I use a pair of Firepods (use Dice 2) with Reaper and I haven't had an issue.
the firepod does not use DICE II.
and DICE II isnt just an incompatiblity with reaper, it sucks, in general.
I built my box specifically with Reaper and my FW Interface in mind and haven't had a problem. Other's have mentioned the DICE-II, and that's what my PreSonus FireStudio 2626 has, so I spent some time looking at known good hardware on their BBS and then hit Newegg with a vengeance.
I think I read somewhere that there was a slight advantage to Intel over AMD when it came to DICE-II as well but I can't remember for sure now, it's been awhile.
+1:D
I'm a newly converted Reaper user (last few days:)) coming from Sonar. I'm using my firepod with it no problems at all, and can honestly say I don't notice any latency at all.
I won't be using firewire in the immediate future, so that's not an issue.
Thanks for the reassurance that Reaper isn't hardware-finicky. :)
Been using a PreSonus FireStudio 2626 my entire run with Reaper, not a single issue.
thats great!!! I wanted to check out the firestudio, but have heard so many examples of it being high latency and crappy, i didnt do so. This is the first time ive heard something favorable about it.
PreSonus just released some new drivers for it late last year. Supposedly it makes the DICE-II work with SONAR which was it's arch nemesis. I haven't upgraded drivers/firmware yet, more of an if it ain't broke don't fix it sort of guy.
I've used my Reaper/PreSonus rig on two different DAW's now, one out of a computer that I had laying around and my new(er) one that I purpose built, and both have been fine. I can send you the specs on it if you want.
The last box I built was specifically for Reaper. Used an io|26 for the interface. Never had any problems with the computer or getting anything to recognize anything else. Only problem I ever had was going too heavy on the VSTs. Apparently 2 GB of RAM and a 2.2 Ghz proc. aren't enough to run upwards of 10 hogging plugins on upwards of 10 tracks...? Heh.
