Gear_Junky
I knew this for a while, but being a "non-tech" hesitated to even open it up, until yesterday. Turned out to be VERY easy, actually (BUT BE ADVISED: THERE ARE VOLTAGES INSIDE THAT CAN KILL YOU, but you don't need to touch those parts to re-bias).
Of course, all this I read somewhere else - not my own info/data. It just so happens that many of these amps (SCXD) come biased rather "cold", apparently a move by Fender to allow people to stick in any matched set of 6V6 tubes without re-biasing (they don't want people poking inside to avoid liability).
This means that re-biasing your stock tubes may get you a NICE improvement in sound - a totally free "mod". My amp started sounding richer (more complex) and notes seem to "bloom" more. More tubey. Granted, maybe your tubes will last a LITTLE less, but now that you know how easy it is to re-bias - installing new tubes will be a no-brainer and they'll always sound their best! That's the whole point of tube amps - TONE, not lack of maintenance
To find instructions with pictures simply google "bias SCXD", but it's really simple - inside there's a blue trim pot on the circuit board - it takes a regular flat screw-driver (insulated handle, please!). Set the multi-meter to DC volts (you're measuring 40 milli-volts or .004 volt). Stick the black (ground) probe to the chassis and use the red probe to touch the end of the resistor R20 (the end closest to the printed "R20"). Adjust trim-pot to 40 mV - done.
Again, please don't take this as complete instructions - find the full writeup on google, but doing this helps the amp sound it's best! Highly, HIGHLY recommended. Even if you have a tech do this, it should take a pro maybe 15-20 minutes (most of which is just removing the rear panel and the amp from cabinet) - so this shouldn't cost a lot.
and the value of 40 mV (20 mA per tube) was suggested by BillM among others - he's one of the foremost modders and "students" of this particular amp (and other fender amps) and this value reportedly comes from Fender documentation for this amp, so hopefully it's not too "blindly" used
and I'd even learn to work on it, but I can't afford it and don't even have time - hardly even finding time to play, much less mod.
