Newbie here. I'm a little confused. Is a Compressor/Limiter and preamp the same thing?
Nope. A compressor and a limiter are related; the main difference is in how radical or severe one can push their settings, with a limiter winning that contest.
JP, I recommend you head over to
www.independentrecording.net, scroll down to the bottom right of the front page and click on the "Compression Uncompressed" logo. This will pop up an introductory, yet extensive tutorial on compression, compressors, and limiters, along with how they work and their use(s) in all phases of the recording process.
The generic term "preamp" simply referrs to any device *or circuit within a device* that can control or boost signal level. For example, your dbx166 has a "output gain" knob with controls a preamp circuit for raising/lowering the volume of the output signal from the device. But that circuit is only one signal stage within the 166 and actually has nothing to do with it's compressing or gating capabilities.
Another more common usage of the term "preamp" around here is when it refrerrs specifically to a microphone preamp, which is a device or circuit specifically designed to bring the low output voltage from a microphone up to the higher voltages expected by and designed into the standard connections between boxes.
Also, what is normalizing? Is it the same thing or is it used when you try to get all the tracks of an album at a consistent volume level?
Standard normalization - actually more specifically called "peak normalization" - is nothing more than a volume control. What it does is take a look at your whole digital wavefrom in your DAW software, determines the volume of the loudest peak in the signal and then boosts the whole signal by the amount of digital decibels (dBFS) required to bring that peak to makimum volume. For example, if the highest peak in your song hits, say, -4dBFS (with 0dBFS being maximum), the normalizer will boost the entire signal level of your song by 4dB.
There is another type of normalization called "RMS normalization", but it is much rarer and more difficult to properly explain, so I'll skip it here because as a newb you probably won't encounter it much just yet, but if you find yourself bored and curious, you can try searching this forum for "RMS normalization" for more info on that.
There are not a whole lot of realistic uses for normalization, to be honest. Because of the nature of sound and the human ear, in real life such normalization rarely actually makes two signals sound as if they are the same volume. Just because their peak levels are made the same loudness doesn't mean that the remaining 99.999% of the levels will sound the same. Frankly, for a half-dozen different good reasons, you're best off understanding but just staying away from normalization in your endeavors.
HTH,
G.
P.S. A six year old newbie?
