W
whattaguy
I know that you would want the power amp and the speakers to somewhat match in impedance and wattage (erring on the side of more for the speakers), but what happens when you bridge an amp, or run speakers in parallel?
For example, I have a speaker with these specs:
Frequency range: 52Hz - 20k Hz
Frequency response: 65Hz - 20k Hz
Sensitivity: 98dB SPL
Nominal impedance: 8 ohms
Power capacity: 400 W / 800 W / 1600 W
Rated maximum SPL: 124 dB SPL continuous (130 dB SPL peak)
How would I read that and choose the correct power amp?
What if I wanted to go 2 speakers on each side, how would I choose my power amps?
Thanks.
Thanks.
