S
sarsipius
Which one is best? I have the option to use any of the three in Sonar PE6. Which one has the lowest latency?
I use a firepod and i actually found it works better using the "asio4all" driver, which you can find on google. Gave me smooth playback and no stops, plus it has some good latency options on it. Just a thought
Mike-
when you say interface do you mean my delta AP192? There is no selection on the 192 panel to select the driver. In sonar PE I can choose ASIO MME or WDM.
thats a unique flaw to Presonus, though. You will be best off choosing ASIO driver in Sonar. Note that using the ASIO driver means exclusive use of the device. i.e. you cannot be playing Media Player or iTunes while running Sonar (and you shouldn't do that anyways).
