I think he was implying do you mix out of or in the box. Of course you still need an interface to record using a mixer, but you can route your signals around so all your mixing is done on the mixer. However, the cost of a mixer with good routing and pres tends to cost a bit more than an interface with similar options. But then again, if you get a control surface you're probably gonna be running at about the same.
