J
jerberson12
mucis procedure
Hi guys,
Assuming that you track a vocal from good condenser mic thru a preamp (assuming all the settings are off or flat, no eq, no comp, no deesser ) thru your audio interface/recording software (nothing else). After recording the track, what do you usually do if you would have to use the eq first?
If you listen to it before editing , you can hear it in full frquency from 20 to 20k or fat and wide. But if you listen to a vocal from a commercial music, it usually sounds dead center, squeeze, and small. Whats the trick? Im getting frustrated with my vocal or do I just have a crappy mic(MXL V67)?
Do they usually cut subs/basses (lowcut eq) first below, then compress?
