Oh, oh. You had better watch what you say, and separate fact from wishful thinking and marketing hype. Someone will use this against you.
FACT #1: A magnet simply provides the emf force for the voice coil. Sound does not travel through any magnet material. THE CAUSE AND EFFECT OF HAVE A LARGER CERAMIC MAGNET IS A HORSE OF A DIFFERENT COLOR! This is because.........
FACT #2: The 'hot response' is perceived because people compare apples to oranges. A 16 oz. Ceramic magnet does not have the same flux density as 16 oz. of Alnico, and that's not even taking into account the differences between cast and sintered Alnico. If you have the same Gauss level,
then we are comparing apples to apples, or at leat a MacIntosh to a Granny Smith. This is difficult to compare because.....
FACT #3: You didn't see many 100-watt Alnico speakers. Those low-wattage Alnico speakers you
did see in your vintage Fender had a smaller plate gap and a small diameter voice coil. And they had nice felt dust caps. Now try and find a 15-watt Ceramic speaker. You'll have better luck finding a 100-watt Ceramic speaker with an aluminum dust cap, a 2" voice coil, and other differences.
FACT #4: You
can hear differences in higher efficiency speakers, doped surrounds or raw surrounds,
how much doping, smooth or ribbed cones, etc. And most people look beyond all that and focus on the magnet. Yeah, it's that Alnico that made it sound warmer
If you could make an identical speaker; the
same paper, the
same surround, the
same plate gap, the
same voice coil, the
same cast frame, but made one with an Alnico magnet and one with a ceramic magnet, I really doubt you'd hear balck and white differences. I'll wager a wooden nickle it would at best be more subtle, like say plain vanilla to French vanilla. And that's a big maybe.
Use the speaker that has the properties you want. If you want all amplifier distortion, and the speaker just to accurately reproduce
that, then get a JBL, or some high powered, high efficiency, ribbed, doped speaker. If you want speaker distortion, maybe some 'cone cry', then you want something else entirely. Clear as mud? You're welcome
. Now, where's my flame-proof suit?
