A
amplifire
Hi, I've been searching this forum for patchbay info for a while now and can't seem to find the answer to my question...I am running Cubase SX4 and have a Tascam FW-1082. I have some outboard gear (Compressors, FX, Limiters) that I would like use with a patchbay. What I don't understand is how can I hook up the patchbay to the FW-1082? It only has 1 set of outputs for monitors. I want to be able to record a dry signal and then route it through an effect and then record the new sound on another track.
For example, I mainly record vocals...I would like to record the vocal "dry" and then apply different effects or compression to it. Then I want to record the modified sound to another track. I just don't see how this is possible with a DAW with only 1 set of outputs? I have heard that I should hook the patchbay up to the insert lines of channels 1&2 but this doesn't seem right...
Please help. Thanks in advance.
