Toddskins
Member
I am confused and not getting the results I desire. I'm trying to program my Setups to cooperate with the Songs I have created, to play live performances with background accompaniment.
Can somebody please explain to me in which place to define the KDFX studio to be used? It seems like there are 2 different places it can be done?
1) In Song mode, you tell the Kurzweil to use the channel associated with a certain program on a particular track. Everything is fine if you are hitting "Play" while in Song mode. But, things get complicated when you move over to Setup mode and now play the Song associated with that Setup.
2a) In Setup mode, it has its own KDFX Studio pages.
2b) In Setup mode, under Common, you tell the Setup to use a specific Song, and so now when the Song is being played as accompaniment to the Setup, which KDFX is being used?
Do you see the problem I am having? I cannot ascertain what is happening if KDFX is "on" for a song (using the KDFX associated with a particular Program on a specific track), which is then also being played during a Setup performance, and the Setup also has its own KDFX studio.
I have turned the Setup KDFX studio off, but am getting strange results. For example, when I play the song while in Song mode, I get one result, but cannot duplicate that result when I switch over to Setup mode, and hit the play button for the Song.
I have also turned off the internal FX (the Digitech chip) to see if that was causing the problem, but it is not.
Help please?
Help please?
