DavidK
Is a song fades out and is going to be mastered by a pro, who fades it out?
A. You
B. Master Engineer
My guess is B?
A. You
B. Master Engineer
My guess is B?
A. You
B. Master Engineer
My guess is B?
Hey John,As long as the fade is done correctly (you'd be absolutely shocked how many are not)
A:Me. I am the only one who knows how my fade will be. Could be long, short or anywhere inbetween.
Hey John,
What would constitute an incorrectly-done fade?
G.
As judged by who?one that is inappropriate for the song....the wrong "curve" maybe, too quick, too slow...
Custom per-track fades is a fairly cool creative element not to mention a good example of where it's simply the right thing to polish up' on held out end chords and such. Trimming guitars, basses fading off at different rates, falling into their noise levels....One of the greatest things about digital mixing is the ability to fade out individual elements individually... And some people seem to not want to crank up the volume to check them.
I prefer to have the ME do it.
Limiters are not a problem, as they do nothing in quite sections to begin with. I agree that compression can be a problem, though. Sometimes, I undid a fade, applied all dynamic processing necessary and finally exactly remade the fade in every respect the song had in the beginning.I prefer to have the ME do it. That way, the compression and limiting done in the mastering process doesn't fall apart as the song fades and the music drops below the threshold of the compressors and limiters.
The big problem on this is that it depends very much on the listening environment. In one situation, a listener could not make anything lower than -30 dB while in another situation -70 dB might be still clearly audible. Thus counting on that is pretty much futile.because sometimes it can make all the difference just which beat of which measure is the last thing the listener hears. Sometimes one wants to end on a wimpy beat, sometimes just squeezing in that last vocal scream or guitar mini-riff before silence puts a nice punctuation at the end.
True enough. But just because the guy in the car with his windows open can't hear it doesn't mean that one should take that as license to phone it in for the rest. Sure it's not going to make or break a song or a mix, it's a relatively minor detail in the grand scheme of things; but I will never argue against that kind of attention to detail.The big problem on this is that it depends very much on the listening environment. In one situation, a listener could not make anything lower than -30 dB while in another situation -70 dB might be still clearly audible. Thus counting on that is pretty much futile.
Since I do a lot of metal, the limiter is part of the sound. If the song comes out of the limiter, it will fall apart.Limiters are not a problem, as they do nothing in quite sections to begin with.
I wasn't thinking of a limiter used during mixing, but then again, if it's already on the track, it doesn't matter if the fade is done right after that or at the mastering.Since I do a lot of metal, the limiter is part of the sound. If the song comes out of the limiter, it will fall apart.
This is the key, IMHO, and the reason why I say that the fades should be the last thing (or close to it) on the list.if it's already on the track
Of course, I apply a mastering limiter after all edits, including fades.
