kojdogg
bollocks redux!
Anyone know where you can get those slide on connectors for guitar speakers-so you don't have to solder them on- preferably ones which are part of a speaker cable with a 1/4" connector on the other end?
thankfully no... bad idea dude... especially for a speaker level signal... do the right thing and solder some up...
no that's a very good idea d-p, but it likely involves soldering which i generally try to avoid for my own safety, the safety of my loved ones and of the community i live in.
You can damage an amp if the speakers become disconnected. This is the problem with 1/4" phone connectors, and it is not improved with solderless connections.
Even back in 1963, the year my Ampeg B15N was built, they understood the need for secure connections, and that amp used a locking XLR connection to the speaker cab.
My latest amp, a Fender Jazzmaster Ultralight, has Speakon locking connectors and that's the way to go.
Not a lot of power but it was pretty much indestructible, good small club amp.
Mostly you just need to have a solid connection from the amp to the speaker and don't let it run without a speaker for the load, Koj.
Thanks-- I'll definitely look into that.I think people may not understand what you are asking.....you can get a box of crimp connectors and a crimp tool at Radio SHack for about $20....and make a cable with two of those at the speaker end and a 1/4" at the other end.
Thanks Tony-- I generally run the amp through a Weber attenuator first which provides a speaker load unless I'm jamming with other people or playing with a band.Mostly you just need to have a solid connection from the amp to the speaker and don't let it run without a speaker for the load, Koj.
