Yea...thats what I started doing....the tracks that I knew I had the way I wanted them...I just used the Audio Suite and made the changes, and processed and went about my buisiness...I was able to clear out about 12 plugs which made a big differance....
What I like to do here is buss to a new track and record through to the new track, then hide and make inactive the old track. This way its simple to go back and make a quick change if I'm not happy later.
it's kind of the same thing. Bouncing usually refers to the Bounce to Disk command. Bouncing to a new track just avoids the whole process of having to import or even convert your tracks back into Pro Tools. You just change the outputs of the tracks to a bus and set the input of a new track to that same bus. Then press record.
sure. if you have 12 tracks with a bunch of plugins on them...create 12 new tracks and bus the tracks individually to them. Or maybe mix and match them by bouncing all the guitars together, all the drums together, etc. Then you can just disable the original tracks so you still have them in case you need to go back and change something.
