I
Illmatic Enzo
Does a low cut switch on a microphone kill some of the bass from the vocals?
Thank you
So since I have ahigh pitched voice would it be best to leave the filter off?
Yep.. This is typically the reason why I use it...But by using it, you might eliminate room noise, the rumble of trucks, the hum of a central air conditioner.
Randy
Let's not forget the roar of gurgling flatulence, and the occasional moan which can sometimes escape a prostitute who has been chained to a basement wall for days....It's not always that simple. If you have a high voice, you might think there's no low frequencies to worry about. But if there's no low frequency in your voice, you have nothing to lose by using the rolloff. But by using it, you might eliminate room noise, the rumble of trucks, the hum of a central air conditioner.
So like Cosmic said--Try both.
Randy,
Does your rolloff cover the frequency of your tractor? Or does no one other than you use the tractor?![]()
LOL!
I don't let very many people use my tractor... My wife drove it one time...about 1 year ago... This is my favorite toy!
Randy
I appreciate everyones input
Ok this is my set up I'm using an at4040 mic to a art tube project series preamp to a soundcard on a laptop........I use it for only rap vocals......I have the gain turned up 5 db and output -4.......it sounds good....from my understanding gain is the thing that affects the coloration if I can call it that of the vocals.....so would it be best for me to click the 10db cut switch on the mic, hit the +20db boost on the preamp add a lil more gain and turn down the output?
Today's bass cuts are for wussies.
I prefer a much steeper drop.
Start around 1000 hz and just drop it off like a cliff. If you're not man enough to fill out the low end with that kind of drop ... then you might as well go and join the old ladies' church choire.
