Ok, this is a long one, but I'm really trying to help, so please read it!
Here are a list of facts that you may or may not already know.
1 A major scale has 7 (different) notes, and then it starts over again in the next octave.
2 You already know the intervallic pattern (W W H W W W H).
3 The notes of a scale are numered as degrees: the first is 1, or the root (or tonic). 2 is the 2nd, 3 is the 3rd, etc.
4 The interval from 1 to 3 in a scale is a 3rd, because three note names are in involved. In the case of C major, this would be C(1) D(2) E(3) --- C to E is a 3rd.
5 Consequently, D to F is also a 3rd: D(2) E(3) F(4) --- three note names
6 If you measured the intervallic distance from the root to any note in the scale, you'd get all kinds of intervals: C to D is a 2nd, C to E is a 3rd, C to F is a 4th, C to G is a 5th, C to A is a 6th, and C to B is a 7th.
So far, all this does is tell you the interval's quantity (i.e., the number of note names involved). An interval also has a
quality. That's the major, minor, augmented, or diminished part of it.
Ok, now bear with me. Just read through this, and I promise that it's all aiming to answer your "why" question.
You need to learn this chart. It tells you how many half steps each interval is. It's given in reference to a C note, as an example, but any note can be used. Why do you need to learn it? Because understanding intervals is how you understand the way chords are built.
m2 (minor 2nd) 1 half step (C to Db)
M2 (major 2nd) 2 half steps (C to D)
m3 (minor 3rd) 3 half steps (C to Eb)
M3 (major 3rd) 4 half steps (C to E)
P4 (perfect 4th) 5 half steps (C to F)
aug4 (augmented 4th) 6 half steps (C to F#) or dim 5 (diminished 5th) (C to Gb)
P5 (perfect 5th) 7 half steps (C to G)
m6 (minor 6th) 8 half steps (C to Ab)
M6 (major 6th) 9 half steps (C to A)
m7 (minor 7th) 10 half steps (C to Bb)
M7 (major 7th) 11 half steps (C to B)
P8 (perfect octave) 12 half steps (C to C)
There are several things at work here that make learning it easier.
1 Major intervals are always one half step larger than minor ones.
2 Augmented intervals are one half step larger than perfect intervals (they can also be one half step larger than major intervals, but that's a bit advanced right now)
3 Diminished intervals are one half step smaller than perfect ones.
The augmented 4th and diminished 5th interval is the same note: F# = Gb. These notes are said to be
enharmonic. (If you went to the piano, the same black key can be called F# or Gb.) The reason that C to F# is called some kind of 4th is because 4 note names are involved (C D E F). The reason that C to Gb is called some kind of 5th is because 5 note names are involved (C D E F G). The quality (
augmented 4th or
diminished 5th) is because 6 half steps are involved.
Augmented and diminished can also be used to describe other intervals; it's just not as common. For instance, the distance of 8 half steps from C could also be called an aug 5th (one half step larger than a P5th). This would be spelled C to G# and would sound the same as C to Ab. Again though, C to G# is called an aug 5th because 5 note names are involved, and C to Ab is a m6 because 6 note names are involved.
Again, this is all in relation to C. But if you understand what a half step is (one fret on a guitar or one key on a piano), you can relate it to any note. For example here's how this chart would look as measured from D:
D to Eb m2 (1 HS)
D to E M2 (2 HS)
D to F m3 (3 HS)
D to F# M3 (4 HS)
D to G P4 (5 HS)
D to G# A4 (6 HS) or D to Ab d5
D to A P5 (7 HS)
D to Bb m6 (8 HS)
D to B M6 (9 HS)
D to C m7 (10 HS)
D to C# M7 (11 HS)
D to D P8 (12 HS)
Ok, so
why is this so important? Because understanding this shows you how chords are built. The triad is the basic chord. It has 3 different notes (hence the name). There are four different types: major, minor, augmented, and diminished.
Let's go back to our example with C.
A
major triad contains a root, a major 3rd, and a perfect 5th. Looking at our interval chart with C as the root, you can see how to build a C major triad.
C is the root, E is the major 3rd, and G is the perfect 5th. C-E-G
A minor triad contains the root, a
minor 3rd, and a perfect 5th. It's only one note different from a major triad. So, looking at the chart, we would adjust to spelling of C minor to this:
C is the root, Eb is the minor 3rd, and G is the perfect 5th. C-Eb-G
An augmented triad contains a root, a major 3rd, and an augmented 5th. Looking at our chart, we'd spell it this way:
C is the root, E is the major 3rd, and G# is the aug 5th. C-E-G#
And a diminished triad contains a root, a minor 3rd, and a diminished 5th. Our chart would show that it's spelled like this:
C is the root, Eb is the minor 3rd, and Gb is the diminished 5th. (Remember, diminished intervals are one half step smaller than perfect ones.)
Before I go on, let me know if this makes sense so far. If you have any questions, ask them specifically if you can, and I will try to answer them.
