Zaphod B
Raccoons-Be-Gone, Inc.
I mentioned a couple of weeks ago that I was going to build a bypass box so that I could judge the Pod XTL's effect on tone.
I got the parts in last week and built the box on Friday. I've had a couple of days to play around with it - toggling between true bypass and keeping the Pod in the loop with no amp models or effects enabled.
I am using a Vox AC30CC 2 X12 amp, and I have not yet experimented with all the guitars - so far, the Les Pauls and my Xaviere Strat-like guitar.
The short answer is that the Pod does affect the tone, but not very much. Not enough that you'd be able to tell in a blind listening test whether you are listening to true bypass or Pod-in-the-loop. I'd characterize the Pod's effect on tone as causing a very slight loss in clarity (upper mids perhaps?) and a very slight increase in bottom end.
The most difficult part of comparing apples to apples is dialing in the Pod's output level so that it matches the line output level of the guitar. Otherwise any tone difference heard from the amp is as likely to be due to a difference in input level as anything else. That said, with output levels matched as closely as my ears would allow, the tone difference is minimal. So minimal, in fact, that since my bypass box does not have an LED indicator, I couldn't tell which was which unless I enabled an effect on the Pod.
So I think the Pod will serve well as a programmable multieffects floor unit, with the amp modeling stuff not being used.
Having said that, I think that the tube amp ameliorates the effects of the Pod's digital signal chain a bit, because when I listen to the Pod directly though headphones, or input directly into my Tascam, it still sounds a bit Piezo-like and artificial.
Now for something curious and very puzzling, and I would welcome your opinions.
First let me state that the bypass box operates as it should - clearly toggling between the two states. It is well grounded and the box is cast aluminum which means it is well-shielded. I can detect no cross-talk between the two states (for example, with the Pod having a couple of very obvious effects enabled and the box in "bypass," the effects are not audible through the amp).
The Pod has a TAP/TUNE pedal, which doubles as a tap-tempo button, or when held down, invokes an onboard tuner. When the tuner is enabled the output from the Pod is disabled. I was messing around with the setup last night, and to my surprise I found that even when in the "bypass" mode, the Pod is picking up some stray signal - enough for the tuner to work! And, get this - when the Pod is in the loop, with the guitar's volume all the way down, the Pod picks up enough signal for the tuner to work.
I'm really puzzled by this. I can understand that the guitar's volume knob (this happened with the '76 Les Paul Special) might not actually be attenuating all the way, although it seems to be. I can also understand that there may be a little crosstalk occurring in the DPDT switch, but I can't imagine it would be enough to operate a tuner if it's not enough to cause audible crosstalk.
I'm thinking it's a case of a hypersensitive tuner, with a little bit of bypass box crosstalk and a little bit of old volume knob.
Any thoughts?
Any thoughts?
