Drumstick suggestion for v-drums
  • Thread starter Thread starter Vigilante
V
Vigilante
Gear nut
We're about to get some Roland v-drums, a top of the line kit I was told. But someone mentioned that sticks are an issue, that we should get maple sticks?
I don't know about what wood or what tips are best to play on v-drums. Of course we want the drums to last and I don't want anything overkill for them. I am not a super heavy hitter, but I am moderately high when energy goes up.
Suggestions for sticks? Hopefully not to expensive as we'll have to buy many pairs at a time. Also, is all playing with brushes lost on v-drums? Just never read anything about brushes.
Thanks
Any sticks will work fine, but I'd recommend a nylon tip for durability. Wood tips will split/splinter over time, even on e-drums and you could snag the fibers in the mesh head which could possibly (over time) wear thin.
W.
W.
you cant get any better advice on the issue then this. +1
W.
If you do decide to use nylon tip sticks, make sure the tips are completely smooth. Some nylon tips can have very small seam; that is an absolute killer of mesh heads, as well. Generally, I use wood but, as previously stated they can nick/chip too. Therefore, I try and be diligent about inspecting them and limiting the amount of use. If I notice anything on a tip, or even after several good sessions, the sticks go in a bin for use on the acoustic kit.
This is all good advice.
I've been playing a Roland TD10 kit for about 6 years - and have a couple of pair of nylon tip sticks that I only use for that kit (I only use nylon tips, even for acoustic kits). I also have a pair of nylon brushes (never use wire brushes on the mesh heads). I'm not overly anal, but I do periodically check to make sure there is nothing that will snag the mesh.
After 6 years of fairly consistant use I've had no problems with the mesh.
