pipelineaudio
Well, first off, by definition, digital isn't 100% accurate.
Your converters need to see 2 points to convert audio without aliasing, but that is different from the sort of sonic accuracy that we are talking about here.
At 48k, if you were to record a 24k sine wave, you would get two points for every second of audio. It would record 2 amplitudes of that wave each second. Simple math will tell you that if you record that same wave at 96k, you'd get 4 amplitudes/second. This is much more accurate, and would be an audible difference if we could hear this high. (if we had dog's ears, this would be completely obvious.
Now, granted, we can't hear 24k. But when you take the idea of this into account, it would make sense that you would get more detail with higher samplerates, but it would only be much more obvious in the higher end of frequencies.
Read up on Nyquist theory for more info about this.
Im not convinced that two dots inside a bandlimited signal is any less accurate than 100
