DSP2000 C Port 24/96 success-without ASIO?
  • Thread starter Thread starter superspit
superspit
superspit
idiots unite!
Hi,
is anyone here having success with this rather 'obscure' unit, without using ASIO, within the XP sp2 O/S?
Well, I just bought one (probably should have waited for a Delta 1010!), and though my AdobeAudition 1.5 'see's' all the 8 analog outputs (which I feed into a desk), it simply doesn't see any signal (output).
The install disc ("soundtrack audio dsp24") is only good for W98/2000/nt4!
The installation appears to require 2 discs???...anyway, this is where you come in and correct me??
I have downloaded all the drivers (they appear very small, which makes me wonder), from older to newer, with little success, still no output.
If someone here can help me out with a link (which I have tried), or the actual software, that'd be so good.
Thanx.....:)
Spit.
spit, if you join the group, you can see over on the left side of the page is a list of links. The one called "files" will take you to a page that has the most recent manuals in pdf format, and also the most recent drivers.
The card does work in XP, though I'm currently using it in Win2K with the ASIO driver. I'm using an older driver. I can't remeber the version number, but it's working so I never bothered to try a newer driver.
twist
