M
mattkw80
Question :
Can tracks be 'just a little bit' Out of Phase with each other.... or is it pretty much black and white?
My brother's and I took about 4 hours today, to mic the drums in all the different configurations we could possibly think of. Kind of a neat project, with really varied results.
SETUP 1. x2 Audix F15's using Recorder Man setup
(This was by far, the best results)
SETUP 2. x2 SM57's using Recorder Man setup
(Also good - darker than the Audix F15's, less high end, but useable)
SETUP 3. x2 Audix F15's out front of the kit, X/Y config.
(Sounded trashy, not very useable - maybe was reflecting off the back drywall behind the drum kit)
SETUP 4. x2 Audix F15's out front of kit, but spread wide, 110 degrees or so
(A little better than the X/Y but still bright and trashy - again, maybe becsue now I'm pointing at the back wall, where as the recorder man method in Step 1 NEVER points at the back wall).
SETUP 5. "All 8 inputs"
1 - Audix D6 Kick
2 - SM57 Top of Snare
3 - SM57 Bottom of Snare
4 - Audix F15 High Hat
5 - SM58 Top Tom
6 - SM58 Floor Tom
7 - Behringer B-1 Right Room Mic / Overhead
8 - Rode NT2 Left Room Mic / Overhead
*I matched the Behringer B-1 up with the Rode NT2 as overhead pairs, because I didn't have another NT2, and the B-1 I believe is just a Rode NT2 knock off anyway.
(This sounded really good. Had to phase invert the bottom snare mic - which I think it pretty standard. We all still favored SETUP #1 to this, in several blind tests we did.)
Sorry to make a long post, but I have to explain all this to properly ask my question.
With Setup #1, which sounded the best, I would like a little more control over the KICK and SNARE after it's all said and done. But the recorder man method is measured out in such as way, that you should not have any phase issues, and I'm worried that adding a snare mic and a kick mic could throw the entire thing out of whack.
My second question is in regards to setup #5.
Obviously the bottom snare mic was out of phase with the top snare mic. But does inverting the phase not then potentially put it out of phase with say, the high hat, or the kick drum - which bleed into that mic quite a bit considering it's close location to both of those things ?
When I run those 8 tracks of drums, is it possible that each track could be slightly out of phase with the next one?
Can I use a plug-in of somesort or metering to be really sure?
1 - Audix D6 Kick
5 - SM58 Top Tom
6 - SM58 Floor Tom
