J jndietz The Way It Moves Dec 13, 2007 #1 What do you think was done to get the kick to have such POWER in these recordings? http://www.mediafire.com/?9uygydd8zjn
MadAudio Damned if I do Dec 17, 2007 #5 Sloan said: sample, eq, comp, limit, coke, limit, limit. clip, limit. Click to expand... LMAO!!!!
Sonixx New member Dec 18, 2007 #6 Good sounding kick Proper Mic and Placement Compression EQ Reverb or Samples Compression EQ Reverb Sounds like some Reverse Reverb also Here's short demo I just through together using Reverse Reverb and Parallel Compression over a drum loop. this demo is the whole kit as one would probably treat the drums individually and this is over done... but you'll get the picture Kit Demo there are four sections 1. Dry 2. Reverse Reverb 3. Parallel Compression 4. Reverse Reverb + Parallel Compression . Last edited: Dec 18, 2007
