L
Leffield
Currently I have ACID Pro 6, but will consider picking up Sonar or Ableton [or other recommendations if what I describe below is functionally and easily implemented]
How can I map specific wav files stored on the computer to be triggered by my external keyboard MIDI controller for use in tracks? Once this is done and a track is created using those samples, there will be no need to keep the external controller connected for playback of the track, because both the MIDI commands and the audio will be saved in the ACID project, right?
Also, how can I create my own "VST" instruments based on personally captured samples, VS. commercial VST instruments?
Finally, what are some of the best VST drum kits available? [acoustic kits to be used in hiphop production]
I know there are several questions here. Thank you much for any info provided.
__________________
__________________
